Amazon Fire 5th Generation Battery Replacement
Выберете то, что вам нужно
  1. Amazon Fire 5th Generation Battery Replacement, Remove front screen assembly: шаг 1, изображение 1 из 2 Amazon Fire 5th Generation Battery Replacement, Remove front screen assembly: шаг 1, изображение 2 из 2
    • Ensure that your device is turned off.
    • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
    • Holding the Fire firmly, wedge a plastic opening tool into the crease on the edge of the device.
    • Slowly work the plastic opening tool around the device until the entire back cover releases from the front of the device.
    Спросите у FixBot
    Добавить комментарий
  2. Amazon Fire 5th Generation Battery Replacement: шаг 2, изображение 1 из 3 Amazon Fire 5th Generation Battery Replacement: шаг 2, изображение 2 из 3 Amazon Fire 5th Generation Battery Replacement: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    $3.99
    • Using angled ESD precision tweezers, lift up on the battery cables to separate the battery connector from its socket.
    • Be sure to lift the battery connector cables themselves and not the actual socket. Doing this step incorrectly could damage the connector.
    Спросите у FixBot
  3. Amazon Fire 5th Generation Battery Replacement: шаг 3, изображение 1 из 3 Amazon Fire 5th Generation Battery Replacement: шаг 3, изображение 2 из 3 Amazon Fire 5th Generation Battery Replacement: шаг 3, изображение 3 из 3
    • Carefully and slowly work a large plastic opening tool along the edge of the battery pack. Angle the tool to pry it up.
    • When you have successfully lifted the battery pack up on one side or corner, carefully wedge the opening tool under the pack about 1/2" and work around the rest of the sides.
    • Be careful not to bend the battery. Don't use too much force, as it can damage the battery.
    Спросите у FixBot
Заключение
25 человек успешно провели ремонт по этому руководству.
Maximilian Plavcan
Участник с: 02/10/16
1 239 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-2, Nance Spring 2016 Участник USF Tampa, Team 1-2, Nance Spring 2016
USFT-NANCE-S16S1G2
3 членов
Автор 13 руководств
9 Комментарии к руководству
Where do you purchase the replacement battery (and what part number)?
John LaRue - Ответить Поделиться
Thanks for this guide Maximilian, and also for the link to purchase the battery, commenter Jorge! Those batteries seem to be pretty difficult to find online. Amazon definitely doesn’t make it easy to find them even on their own site, though they seem happy to sell a replacement fire… :)
crimsontideaggie - Ответить Поделиться
Update: I had to do two of these, and it didn’t take me any longer than 10 minutes for either one of them. Easy peasy, thanks for the clear and concise guide.
If the battery connector comes off does it need soldering back on
Ashley Pollen - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 52
За последние 30 дней: 207
За всё время: 26,575
