Amazon Fire Phone Battery Replacement
Выберете то, что вам нужно
  1. Amazon Fire Phone Battery Replacement, Tape the screen: шаг 1, изображение 1 из 1
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
    Спросите у FixBot
    Добавить комментарий
  2. Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: шаг 2, изображение 1 из 3 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: шаг 2, изображение 2 из 3 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: шаг 2, изображение 3 из 3
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
    Спросите у FixBot
  3. Amazon Fire Phone Battery Replacement: шаг 3, изображение 1 из 3 Amazon Fire Phone Battery Replacement: шаг 3, изображение 2 из 3 Amazon Fire Phone Battery Replacement: шаг 3, изображение 3 из 3
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
    Спросите у FixBot
  4. Amazon Fire Phone Battery Replacement, Remove Bracket: шаг 4, изображение 1 из 1
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
    Спросите у FixBot
  5. Amazon Fire Phone Battery Replacement, Disconnect Battery: шаг 5, изображение 1 из 1
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
    Спросите у FixBot
Заключение
22 человек успешно провели ремонт по этому руководству.
Lissandra Ilcyn
Участник с: 10/05/15
889 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 5-7, Maness Fall 2015 Участник Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
5 членов
Автор 20 руководств
14 Комментарии к руководству
Tolle Anleitung DANKE!!
Leo Henn - Ответить Поделиться
The replacement went exactly as presented. My stock battery had pull tabs to release the adhesive, making removal very easy. Thanks for a clear step-by-step guide.
John - Ответить Поделиться
How to bay amazone fire fone battry in pakistan
Manzoor Khan - Ответить Поделиться
where can i get fire phone battery in india
Shiva Sai - Ответить Поделиться
where can i get fire phone battery in UAE Abu Dhabi. It's urgent..
Asheesh Barna - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 30
За последние 30 дней: 84
За всё время: 14,471
