Введение
The power cable is what powers the AmazonBasics. It is connected directly to the motherboard, and will require soldering to remove and replace it.
Выберете то, что вам нужно
Remove the six 14mm PH1 screws holding the bottom cover in place.
Remove the cover by lifting straight upwards.
Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
Remove the two 8mm PH1 screws holding the IR sensor wire in place. This will give you more room to work with later on.
Remove the two 10mm PH1 screws holding the motherboard in place.
Remove the motherboard by lifting straight upwards from the top cover.
To disconnect the power wire, remove the black and white wires on the far edges of the motherboard.
