Введение
hello all, today we will try to repair the angelcare baby monitor.
two rechargeable battery's exploded, the acid was around an electric power cable. so there were two problems :
1 bad connection
2 battery damage.
we will check also the second unit.
Выберете то, что вам нужно
first remove the 2 screws at the green plastic plate.
remove the plastic plate ( battery compartment)
you'll see that there are 2 more screws. Remove them.
now gently remove the green plastic plate arrounf the baby monitor ( arround the screen) use a spudger to click it open.
now open the monitor by clicking it open or slide it open. Sometimes its easier to use a spudger.
2 battery's were exploded so the acid was on the black electric power wire.
use a cotton swab with a little bit of destilled water.
pull the first PCB up and remove the screws of the second PCB.
after removing the two PCB's, clean the acid on the PCB.
after cleaning the PCB's put it al together again.
first remove the battery lid. 1 screw.
slide it out like you see in picture
remove battery's
6 человек успешно провели ремонт по этому руководству.
13 Комментарии к руководству
Thanks for this. I couldn't figure out how to get the blue clip off without breaking it to clean some dirt on the screen. Googled it, found this, job done.
Sometimes the activity of the reference quartz is 11,150 MHz, and the devices do not find each other.
I have so repaired the parent module.
Dmitriy, the city of Volzhsky.
Hi Dimitriy - I am experiencing the issue with not finding devices each other. How have you fix it ? Is it a matter of replacing the reference quartz with new one ?
Hi. At my Angelcare (AC401) parent unit the screen has slowly become worse and worse. At first, parts of the temperature figures dissapeared, then the symbols around and now I no longer see anything... But the unit still works! (And alert me if the baby's crying) What do you think, is there anything I can do or do I need to buy a new one?
Hi There. I’m having the same problem. Did you find a fix or did you buy a new unit?
