Apex Tablet 7 Camera Replacement
Выберете то, что вам нужно
    1. Apex Tablet 7 Camera Replacement, Back Panel: шаг 1, изображение 1 из 1
      • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
      Спросите у FixBot
      Добавить комментарий
    2. Apex Tablet 7 Camera Replacement: шаг 2, изображение 1 из 2 Apex Tablet 7 Camera Replacement: шаг 2, изображение 2 из 2
      • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
      • This connection is shown in red on the pictures.
      Спросите у FixBot
    3. Apex Tablet 7 Camera Replacement: шаг 3, изображение 1 из 2 Apex Tablet 7 Camera Replacement: шаг 3, изображение 2 из 2
      • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
      • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
      Спросите у FixBot
    4. Apex Tablet 7 Camera Replacement: шаг 4, изображение 1 из 1
      • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
      Спросите у FixBot
    5. Apex Tablet 7 Camera Replacement: шаг 5, изображение 1 из 1
      • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
      Спросите у FixBot
    1. Apex Tablet 7 Camera Replacement, Camera: шаг 6, изображение 1 из 2 Apex Tablet 7 Camera Replacement, Camera: шаг 6, изображение 2 из 2
      • Gently remove the black tape covering the camera and circuit board. The tape will be connected to a foamy block on the back of the actual camera component.
      Спросите у FixBot
    2. Apex Tablet 7 Camera Replacement: шаг 7, изображение 1 из 1
      • Flip the black latch over the gold cable to the upright position in order to release the cable.
      Спросите у FixBot
    3. Apex Tablet 7 Camera Replacement: шаг 8, изображение 1 из 1
      • Carefully remove the cable from the circuit by pulling it straight out.
      Спросите у FixBot
    4. Apex Tablet 7 Camera Replacement: шаг 9, изображение 1 из 1
      • Pull out the camera. There should not be any more connections holding it in place.
      • Reconnect the replacement camera.
      Спросите у FixBot
Заключение
To place the new part and reassemble your device, follow these instructions in reverse order.
Еще один человек закончил это руководство.
Steven Gutzwiller
Участник с: 03/20/15
480 Репутация
Автор 3 руководств
Команда
Baylor, Team 2-2, Grigsby Spring 2015 Участник Baylor, Team 2-2, Grigsby Spring 2015
BU-GRIGSBY-S15S2G2
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 27
За всё время: 724
