Введение
Replacing the keyboard is an easy repair that is unfortunately necessary in certain cases. This guide will take you through the process of removing your keyboard step by step.
Выберете то, что вам нужно
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
4 человек успешно провели ремонт по этому руководству.
