Apple PowerBook G3 400 RAM Replacement
Выберете то, что вам нужно
    1. Apple PowerBook G3 400 RAM Replacement, Keyboard: шаг 1, изображение 1 из 1
      • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
      • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
      Спросите у FixBot
      Добавить комментарий
    2. Apple PowerBook G3 400 RAM Replacement: шаг 2, изображение 1 из 1
      • Pull the keyboard ribbon vertically from the logic board to release connection.
      • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
      • Remove battery and CD/DVD drives before proceeding any further.
      Спросите у FixBot
    3. Apple PowerBook G3 400 RAM Replacement: шаг 3, изображение 1 из 1
      • Your computer should look approximately like this.
      Спросите у FixBot
    1. Apple PowerBook G3 400 RAM Replacement, RAM: шаг 4, изображение 1 из 1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
      • Lift the heat shield up and toward you.
      Спросите у FixBot
    2. Apple PowerBook G3 400 RAM Replacement: шаг 5, изображение 1 из 1
      • Pull the PRAM battery cable vertically upward to disconnect it.
      • Remove the battery by pulling up and to the left.
      Спросите у FixBot
    3. Apple PowerBook G3 400 RAM Replacement: шаг 6, изображение 1 из 1
      • Remove the two T8 Torx screws that attach the heat sink to the processor.
      • Remove the long silver Phillips #1 screw from the heat sink.
      Спросите у FixBot
    4. Apple PowerBook G3 400 RAM Replacement: шаг 7, изображение 1 из 1
      • Lift up the heat sink unit from the left side and remove.
      Спросите у FixBot
    5. Apple PowerBook G3 400 RAM Replacement: шаг 8, изображение 1 из 1
      • Lift the processor on the right side and pull directly up.
      • The RAM chips should be in the slots on the processor.
      Спросите у FixBot
    6. Apple PowerBook G3 400 RAM Replacement: шаг 9, изображение 1 из 1
      • After removing the RAM, your laptop should now look like this.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Ian
Участник с: 04/18/11
57 Репутация
1 руководство автора
Команда
Cal Poly, Team 4-2, Regan Spring 2011 Участник Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 членов
Автор 42 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 35
За всё время: 2,539
