Введение
This guide will show you how to properly get into your Apple TV 4K's remote and get access to the logic board for replacement.
Выберете то, что вам нужно
Heat iOpener according to manufacturer's instructions.
Place over the face of the remote to soften the adhesive under the glass.
Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
Инструмент, используемый на этом этапе:Tweezers$4.99
Unlatch the connector that binds the touch screen and logic board.
Afterwards, use tweezers to detach the connector that binds the touch screen to the logic board.
Lift the latch holding back the connector to the battery.
Use tweezers to disconnect the battery connector.
Using a plastic spudger, gently remove the logic board from the case of the remote.
4 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Have you ever successfully reconnected the ribbon cable after disassembly? It seems nearly impossible to do by hand…
I can’t find replacement adhesive that fits. How are people getting this thing to stick back together when you’re done??
