Apple Time Capsule Model A1254 Fan Replacement
Выберете то, что вам нужно
  1. Apple Time Capsule Model A1254 Fan Replacement, Back Plate: шаг 1, изображение 1 из 3 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: шаг 1, изображение 2 из 3 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: шаг 1, изображение 3 из 3
    • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
    • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
    • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
    • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
    Спросите у FixBot
    Добавить комментарий
  2. Apple Time Capsule Model A1254 Fan Replacement: шаг 2, изображение 1 из 2 Apple Time Capsule Model A1254 Fan Replacement: шаг 2, изображение 2 из 2
    • Remove the ten 3mm screws with a Phillips #00 screwdriver.
    • The screws with adhesive covering do not need to be removed.
    Спросите у FixBot
  3. Apple Time Capsule Model A1254 Fan Replacement: шаг 3, изображение 1 из 2 Apple Time Capsule Model A1254 Fan Replacement: шаг 3, изображение 2 из 2
    • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
    • Pull the base of the wire close to the logic board and the connector will pop off.
    Спросите у FixBot
  4. Apple Time Capsule Model A1254 Fan Replacement, Fan: шаг 4, изображение 1 из 2 Apple Time Capsule Model A1254 Fan Replacement, Fan: шаг 4, изображение 2 из 2
    • Orientate the back plate so that the fan is facing away from you.
    • Use the #0 Phillips Screw Drive to push the rubber shock mounts through the back plate.
    • Make sure that the head of the screw driver is centered on the head of the rubber shock mount so that it doesn't slip off causing possible injury.
    • When attaching the new fan, push the new rubber shock mounts through the back plate first. Attach the fan once all mounts are inserted.
    Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
JR Alfano
Участник с: 10/06/16
543 Репутация
1 руководство автора
Команда
Cal Poly, Team 4-2, Livingston Fall 2016 Участник Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
4 членов
Автор 17 руководств
2 Комментарии к руководству
Hi where can I find the new rubber shock mount replacement for A-1254 fan replacement? thx.
V Q - Ответить Поделиться
How do I get the rubber feet off the old fan and put them on the new fan?
Jim Matthews - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 69
За всё время: 5,344
