Apple Watch Series 6 Screen Replacement
Выберете то, что вам нужно
  1. Apple Watch Series 6 Screen Replacement, Power down the watch: шаг 1, изображение 1 из 2 Apple Watch Series 6 Screen Replacement, Power down the watch: шаг 1, изображение 2 из 2
  2. Apple Watch Series 6 Screen Replacement, Safety Requirements: шаг 2, изображение 1 из 3 Apple Watch Series 6 Screen Replacement, Safety Requirements: шаг 2, изображение 2 из 3 Apple Watch Series 6 Screen Replacement, Safety Requirements: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Safety Glasses
    $3.19
    Купить
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch Series 6 Screen Replacement, Soften the display adhesive: шаг 3, изображение 1 из 1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
  4. Apple Watch Series 6 Screen Replacement, Display opening: шаг 4, изображение 1 из 3 Apple Watch Series 6 Screen Replacement, Display opening: шаг 4, изображение 2 из 3 Apple Watch Series 6 Screen Replacement, Display opening: шаг 4, изображение 3 из 3
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
  5. Apple Watch Series 6 Screen Replacement: шаг 5, изображение 1 из 3 Apple Watch Series 6 Screen Replacement: шаг 5, изображение 2 из 3 Apple Watch Series 6 Screen Replacement: шаг 5, изображение 3 из 3
    • Insert an opening pick in the gap your created.
    • Slide the opening pick along the short edge of the watch to cut the adhesive.
  6. Apple Watch Series 6 Screen Replacement: шаг 6, изображение 1 из 2 Apple Watch Series 6 Screen Replacement: шаг 6, изображение 2 из 2
    • Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to cut the display adhesive.
  7. Apple Watch Series 6 Screen Replacement: шаг 7, изображение 1 из 2 Apple Watch Series 6 Screen Replacement: шаг 7, изображение 2 из 2
    • Slide the opening pick around the corner to cut the remaining adhesive on the short edge of the watch next to the watch crown.
  8. Apple Watch Series 6 Screen Replacement: шаг 8, изображение 1 из 2 Apple Watch Series 6 Screen Replacement: шаг 8, изображение 2 из 2
    • Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
    • Try not to slice near the watch crown to prevent damaging the display cables. If you must slice near the crown, don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
    • Slide an opening pick under the opposite display edge of the watch crown.
    • Twist the opening pick to loosen the display off the watch case.
    • Don't try to remove the display. It is still connected to the watch assembly.
  9. Apple Watch Series 6 Screen Replacement: шаг 9, изображение 1 из 3 Apple Watch Series 6 Screen Replacement: шаг 9, изображение 2 из 3 Apple Watch Series 6 Screen Replacement: шаг 9, изображение 3 из 3
    • Be careful not to strain the display cables when you fold the display to the side.
    • Lift the display and carefully pull it towards the watch crown.
    • Swing the display open to an upward position.
  10. Apple Watch Series 6 Screen Replacement, Soften the battery adhesive: шаг 10, изображение 1 из 1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the rear side of the watch to loosen the battery adhesive. Leave the iOpener on the watch for at least two minutes.
  11. Apple Watch Series 6 Screen Replacement, Determine which procedure to follow: шаг 11, изображение 1 из 1
    • From this point, the battery removal procedure for the 40 mm watch differs slightly from the 44 mm version.
    • If you're replacing the battery for a 40 mm watch, continue with this step.
    • If you're replacing the battery for a 44 mm watch, continue with this step.
  12. Apple Watch Series 6 Screen Replacement, Pry up the battery: шаг 12, изображение 1 из 3 Apple Watch Series 6 Screen Replacement, Pry up the battery: шаг 12, изображение 2 из 3 Apple Watch Series 6 Screen Replacement, Pry up the battery: шаг 12, изображение 3 из 3
    • The following four steps show how to remove the battery from a 40 mm Apple Watch Series 6.
    • Insert an opening pick between the battery and the Taptic Engine.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  13. Apple Watch Series 6 Screen Replacement, Move the battery: шаг 13, изображение 1 из 3 Apple Watch Series 6 Screen Replacement, Move the battery: шаг 13, изображение 2 из 3 Apple Watch Series 6 Screen Replacement, Move the battery: шаг 13, изображение 3 из 3
    • The battery flex cable is long enough to allow you to place the battery outside the watch case, but avoid straining the cable when you lift the battery out of its recess.
    • Carefully lift and swing the battery out of its recess.
  14. Apple Watch Series 6 Screen Replacement, Disconnect the battery: шаг 14, изображение 1 из 2 Apple Watch Series 6 Screen Replacement, Disconnect the battery: шаг 14, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the battery connector.
  15. Apple Watch Series 6 Screen Replacement, Remove the battery: шаг 15, изображение 1 из 1
    Tesa 61395 Tape
    $5.99
    Купить
    • Remove the battery.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you're reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
    • Alternatively, remove the old adhesive with high concentration isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
  16. Apple Watch Series 6 Screen Replacement, Pry up the battery: шаг 16, изображение 1 из 3 Apple Watch Series 6 Screen Replacement, Pry up the battery: шаг 16, изображение 2 из 3 Apple Watch Series 6 Screen Replacement, Pry up the battery: шаг 16, изображение 3 из 3
    • The following four steps show how to remove the battery from a 44 mm Apple Watch Series 6.
  17. Apple Watch Series 6 Screen Replacement, Move the battery: шаг 17, изображение 1 из 3 Apple Watch Series 6 Screen Replacement, Move the battery: шаг 17, изображение 2 из 3 Apple Watch Series 6 Screen Replacement, Move the battery: шаг 17, изображение 3 из 3
    • The battery flex cable is long enough to place the battery outside the watch case during the following procedure but avoid straining it when lifting the battery out of its recess.
    • Carefully lift the battery out of its recess and place it outside the watch case opposite to the Taptic Engine.
  18. Apple Watch Series 6 Screen Replacement, Remove the battery connector screw: шаг 18, изображение 1 из 1
    • Remove the single 1.2 mm-long tri point Y000 screw.
  19. Apple Watch Series 6 Screen Replacement: шаг 19, изображение 1 из 2 Apple Watch Series 6 Screen Replacement: шаг 19, изображение 2 из 2
    • Use a pair of tweezers to remove the metal shield covering the battery connector.
  20. Apple Watch Series 6 Screen Replacement: шаг 20, изображение 1 из 2 Apple Watch Series 6 Screen Replacement: шаг 20, изображение 2 из 2
  21. Apple Watch Series 6 Screen Replacement, Remove the battery: шаг 21, изображение 1 из 1
    Tesa 61395 Tape
    $5.99
    Купить
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
  22. Apple Watch Series 6 Screen Replacement, Peel off the protective foil: шаг 22, изображение 1 из 3 Apple Watch Series 6 Screen Replacement, Peel off the protective foil: шаг 22, изображение 2 из 3 Apple Watch Series 6 Screen Replacement, Peel off the protective foil: шаг 22, изображение 3 из 3
    • Use a pair of tweezers to carefully peel the black protective tape off both display connectors.
  23. Apple Watch Series 6 Screen Replacement, Release the display cables: шаг 23, изображение 1 из 3 Apple Watch Series 6 Screen Replacement, Release the display cables: шаг 23, изображение 2 из 3 Apple Watch Series 6 Screen Replacement, Release the display cables: шаг 23, изображение 3 из 3
    • Use the pointed end of a spudger to pry up the lock bars on both ZIF connectors securing the display cables.
  24. Apple Watch Series 6 Screen Replacement: шаг 24, изображение 1 из 3 Apple Watch Series 6 Screen Replacement: шаг 24, изображение 2 из 3 Apple Watch Series 6 Screen Replacement: шаг 24, изображение 3 из 3
    • Use a pair of tweezers to carefully peel off the edges of the sticker which adheres the display and the grounding cable to the rear side of the screen.
  25. Apple Watch Series 6 Screen Replacement: шаг 25, изображение 1 из 2 Apple Watch Series 6 Screen Replacement: шаг 25, изображение 2 из 2
    • Use a pair of tweezers to pull both display cables out of the ZIF connectors.
    • Do not pull on the watch assembly, or you may rip the display cable.
  26. Apple Watch Series 6 Screen Replacement, Remove the screen: шаг 26, изображение 1 из 1
    • Separate the watch assembly and the screen.
Заключение
To reassemble your Apple Watch Series 6 follow these instructions in reverse order to reattach the screen and the battery.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
35 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
203 632 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 125 руководств
20 Комментариев
Can anyone tell me what that 3rd cable is (circled red in the pic linked below)? It’s linked to the metal back in the phone?
https://imgur.com/0meecS9
gauntletmm - Ответить
I think it is just a grounding wire.
Daniele Carminati -
Did you ever find out what that third wire is?
Antonio Silva Carrillo -
I want to know too, I break it while pulling the battery yesterday, but the watch seems working fine
Coco -
It’s a shield (grounding) line to control EMI noise
Dan -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 79
За последние 7 дней: 436
За последние 30 дней: 1,934
За всё время: 104,862
