Введение
This guide will guide you through how to install Arch Linux using a live system and an installation medium with the official installation image. This guide will walk you through the step-by-step process of setting up Arch Linux, providing you with a clear understanding of each crucial stage, from preparing the installation medium to configuring the system post-installation.
Выберете то, что вам нужно
Download the official Installation Image from the Arch Linux Download page.
While it isn't a required step, it is recommended to verify the image before trying to use the ISO file.
Use GnuPG and import the Arch Linux Developer Key with the following command.
Once completed, navigate to the directory where your ISO file and the signature file are located. You can then verify the signature with the following command.
Navigate to the BalenaEtcher website and download the appropriate version of BalenaEtcher for your operating system.
Insert your USB drive into your computer and launch BalenaEtcher. Select the Arch Linux ISO file you downloaded, then choose the USB drive as the target. Click 'Flash' to start the flashing process.
Once the flashing process is complete, you can remove the USB drive.
Power off the computer you want to install Arch Linux onto, and insert the USB drive.
Power on your machine and boot your machine into your BIOS or UEFI settings, and choose the USB drive as your boot option.
Once the live system has loaded, you will be booted into Arch's terminal.
From the Terminal you can partition your disk, format the partitions, and mount the partitions according to your system's requirements.
Use the Pacman package manager to install the base system and essential packages according to your preferences and needs.
Configure the system by setting the hostname, configuring the network, and creating a user account with appropriate privileges. Set up the bootloader and other necessary configurations.
After completing the installation and configuration process, type 'exit' to leave the chroot environment, unmount all the partitions and reboot the system.
Congratulations! You have successfully installed Arch Linux using a live system and a USB drive as the installation medium, with the help of BalenaEtcher.
2 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Also! Die *.iso enthält eine Life-Version. Die will ich nicht haben. Jedesmal starten und alles ist weg. Wahrscheinlich ein Witz und jetzt soll ich wahrscheinlich lachen
Hallo, haben Sie das Installationsmedium (Ihren USB-Stick) entfernt, nachdem die Installation abgeschlossen war?
