Введение
The Astro A20 microphone replacement guide shows the steps of replacing a microphone with the use of a 60 mm extension, Phillips #1 screwdriver, and a new microphone.
Выберете то, что вам нужно
Place one hand on the hard side of the headset ear portion and on the cushion.
Lift the small portion on the edge of the cushion.
Slide the metal spudger underneath the lift part of the ear cushion.
Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
Lift the speaker area.
Disconnect the wires that connect the microphone.
Remove the 7mm screw with a Phillips #1 screwdriver.
9 человек успешно провели ремонт по этому руководству.
5 Комментарии к руководству
worked for me….thanks
listen my mic peace is messed up is there like a fix for that
were? are you getting the new mic from? please link the site
Hi @jrod6t9, here is a link Mikrofon für ASTRO A20 A10 Gaming-Headset Ersatzmikrofon Ersatzteil. Hope this works. Best
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
