Введение
If the Astro A20 will not turn on or the battery will not charge then you will need to replace the battery.
Выберете то, что вам нужно
Place one hand on the hard side of the headset ear portion and on the cushion.
Lift the small portion on the edge of the cushion.
Slide the metal spudger underneath the lift part of the ear cushion.
Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
3 человек успешно провели ремонт по этому руководству.
3 Комментарии к руководству
Does it work for Astro A20 2nd Gen too?
this guide is so wrong! 1st the battery is on the left side by the charging port (a20 2gen)
That head set is A20 gen1 but main board in right side
from 7th pic that is right side
If you have no idea which is left side or right side.
just check where is buttons
