Введение
Use this guide to remove control buttons for cleaning or replacement.
Выберете то, что вам нужно
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers, remove the spacer nuts and washers from each dial post.
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Gently insert a metal spudger under a control button housing.
Rotate the control button around the marked pin.
2 человек успешно провели ремонт по этому руководству.
