Asus 1015E-DS03 Keyboard Replacement
Выберете то, что вам нужно
  1. Asus 1015E-DS03 Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Hold the laptop using both hands with the battery facing upwards.
    Спросите у FixBot
    Добавить комментарий
  2. Asus 1015E-DS03 Keyboard Replacement: шаг 2, изображение 1 из 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
    Спросите у FixBot
  3. Asus 1015E-DS03 Keyboard Replacement: шаг 3, изображение 1 из 1
    • Push the battery upwards and out of the laptop as shown.
    Спросите у FixBot
  4. Asus 1015E-DS03 Keyboard Replacement: шаг 4, изображение 1 из 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    Спросите у FixBot
  5. Asus 1015E-DS03 Keyboard Replacement, Keyboard: шаг 5, изображение 1 из 1
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
    Спросите у FixBot
  6. Asus 1015E-DS03 Keyboard Replacement: шаг 6, изображение 1 из 2 Asus 1015E-DS03 Keyboard Replacement: шаг 6, изображение 2 из 2
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
    Спросите у FixBot
  7. Asus 1015E-DS03 Keyboard Replacement: шаг 7, изображение 1 из 1
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
    Спросите у FixBot
  8. Asus 1015E-DS03 Keyboard Replacement: шаг 8, изображение 1 из 1
    • Using the spudger push the white clips upwards that are holding the cable.
    Спросите у FixBot
  9. Asus 1015E-DS03 Keyboard Replacement: шаг 9, изображение 1 из 2 Asus 1015E-DS03 Keyboard Replacement: шаг 9, изображение 2 из 2
    • Gently pull the strip out of the square slot.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Joe Capriola
Участник с: 03/21/16
494 Репутация
Автор 3 руководств
Команда
Clemson, Team 7-4, Benson Spring 2016 Участник Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 членов
Автор 7 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 48
За всё время: 1,582
