Введение
Replacing your HDD on your Asus laptop is fairly simple. Before you decide a replacement HDD is necessary refer to the troubleshooting page
Выберете то, что вам нужно
Remove the four screws using your Phillips #0 screwdriver to attain access to your Hard Drive.
Remove the panel using a plastic opening tool.
Gently pull the black strip and the Hard Drive should slide right off. Pull your hard drive to the side not up to avoid damage to the slot.
Еще один человек закончил это руководство.
