Введение
RAM stands for Random Access Memory. How much RAM you have determines what kind of tasks you can do simultaneously. This often affects performance in a multitude of ways. This guide will show you how to replace your RAM cards.
Выберете то, что вам нужно
Unscrew the back plate in the middle of the laptop by removing the two 5 mm screws - this will expose the RAM cards.
Pull the tabs and then slide the card to remove the RAM cards. To reinsert a new RAM card, slide the card in and then make sure it clips in with the tabs.
