Введение
Replacing the RAM is very simple in this case. Removing a few screws and a plastic plate will reveal the RAM which can be replaced. This repair would be needed if the RAM is old and PC performance is lacking.
Выберете то, что вам нужно
Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
Еще один человек закончил это руководство.
