Asus X551CA LCD Replacement
Выберете то, что вам нужно
  1. Asus X551CA LCD Replacement, Keyboard Plate Cover: шаг 1, изображение 1 из 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    Спросите у FixBot
    Добавить комментарий
  2. Asus X551CA LCD Replacement: шаг 2, изображение 1 из 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    Спросите у FixBot
  3. Asus X551CA LCD Replacement: шаг 3, изображение 1 из 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    Спросите у FixBot
  4. Asus X551CA LCD Replacement: шаг 4, изображение 1 из 3 Asus X551CA LCD Replacement: шаг 4, изображение 2 из 3 Asus X551CA LCD Replacement: шаг 4, изображение 3 из 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Спросите у FixBot
  5. Asus X551CA LCD Replacement: шаг 5, изображение 1 из 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Спросите у FixBot
  6. Asus X551CA LCD Replacement, Hard Drive: шаг 6, изображение 1 из 1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
    Спросите у FixBot
  7. Asus X551CA LCD Replacement: шаг 7, изображение 1 из 1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
    Спросите у FixBot
  8. Asus X551CA LCD Replacement: шаг 8, изображение 1 из 1
    • Once it is free, remove the hard drive from its internal cavity.
    Спросите у FixBot
  9. Asus X551CA LCD Replacement, Spacer: шаг 9, изображение 1 из 1
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
    Спросите у FixBot
  10. Asus X551CA LCD Replacement: шаг 10, изображение 1 из 1
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
    Спросите у FixBot
  11. Asus X551CA LCD Replacement, WiFi Card: шаг 11, изображение 1 из 1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    Спросите у FixBot
  12. Asus X551CA LCD Replacement: шаг 12, изображение 1 из 1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    Спросите у FixBot
  13. Asus X551CA LCD Replacement: шаг 13, изображение 1 из 1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    Спросите у FixBot
  14. Asus X551CA LCD Replacement, Battery: шаг 14, изображение 1 из 1
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
    Спросите у FixBot
  15. Asus X551CA LCD Replacement, Motherboard: шаг 15, изображение 1 из 1
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
    Спросите у FixBot
  16. Asus X551CA LCD Replacement: шаг 16, изображение 1 из 2 Asus X551CA LCD Replacement: шаг 16, изображение 2 из 2
    • Now, locate the two wires connected to the motherboard.
    Спросите у FixBot
  17. Asus X551CA LCD Replacement: шаг 17, изображение 1 из 2 Asus X551CA LCD Replacement: шаг 17, изображение 2 из 2
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
    Спросите у FixBot
  18. Asus X551CA LCD Replacement: шаг 18, изображение 1 из 2 Asus X551CA LCD Replacement: шаг 18, изображение 2 из 2
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
    Спросите у FixBot
  19. Asus X551CA LCD Replacement: шаг 19, изображение 1 из 1
    • Remove the motherboard from the case by gently lifting it upward.
    Спросите у FixBot
  20. Asus X551CA LCD Replacement, Front Display Bezel: шаг 20, изображение 1 из 1
    • Locate both of the hinges that connect the monitor to the bottom plate cover.
    Спросите у FixBot
  21. Asus X551CA LCD Replacement: шаг 21, изображение 1 из 2 Asus X551CA LCD Replacement: шаг 21, изображение 2 из 2
    • Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
    Спросите у FixBot
  22. Asus X551CA LCD Replacement: шаг 22, изображение 1 из 1
    • Once the screws are removed, the monitor should easily lift away from the bottom plate cover
    Спросите у FixBot
  23. Asus X551CA LCD Replacement: шаг 23, изображение 1 из 1
    • Locate the two stickers that cover up the screws that hold the front bezel in place
    Спросите у FixBot
  24. Asus X551CA LCD Replacement: шаг 24, изображение 1 из 2 Asus X551CA LCD Replacement: шаг 24, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use a pair of tweezers to remove these stickers.
    • The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
    Спросите у FixBot
  25. Asus X551CA LCD Replacement: шаг 25, изображение 1 из 1
    • Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
    Спросите у FixBot
  26. Asus X551CA LCD Replacement: шаг 26, изображение 1 из 1
    • Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
    Спросите у FixBot
  27. Asus X551CA LCD Replacement: шаг 27, изображение 1 из 2 Asus X551CA LCD Replacement: шаг 27, изображение 2 из 2
    • Once the screws are taken out, the front bezel is ready to be removed.
    • Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
    • Gently use hands if necessary to separate the front bezel from the back.
    Спросите у FixBot
  28. Asus X551CA LCD Replacement: шаг 28, изображение 1 из 1
    • Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
    Спросите у FixBot
  29. Asus X551CA LCD Replacement, LCD: шаг 29, изображение 1 из 1
    • Locate the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
    Спросите у FixBot
  30. Asus X551CA LCD Replacement: шаг 30, изображение 1 из 2 Asus X551CA LCD Replacement: шаг 30, изображение 2 из 2
    • Use the Philips #0 screwdriver to remove the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
    Спросите у FixBot
  31. Asus X551CA LCD Replacement: шаг 31, изображение 1 из 1
    • Once the screws are removed, lift up the LCD to expose the wire connecting the back bezel to the LCD.
    Спросите у FixBot
  32. Asus X551CA LCD Replacement: шаг 32, изображение 1 из 1
    • Gently unhook the wire from the back bezel to allow the LCD to be flipped over.
    Спросите у FixBot
  33. Asus X551CA LCD Replacement: шаг 33, изображение 1 из 1
    • Once flipped over, locate the ribbon that is connected to the back of the LCD.
    Спросите у FixBot
  34. Asus X551CA LCD Replacement: шаг 34, изображение 1 из 2 Asus X551CA LCD Replacement: шаг 34, изображение 2 из 2
    • Gently tug on the ribbon to remove it from the LCD.
    Спросите у FixBot
  35. Asus X551CA LCD Replacement: шаг 35, изображение 1 из 1
    • Now that the ribbon has been detached from the back, carefully remove the LCD.
    Спросите у FixBot
Заключение
10 человек успешно провели ремонт по этому руководству.
Josh
Участник с: 04/10/14
2 970 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 7-22, Regan Spring 2014 Участник Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 членов
Автор 15 руководств
1 Комментарий к руководству
You don't need to disassemble the entire unit to get the panel out. Seems an overkill
Res Q Service - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 39
За всё время: 11,341
