Asus X551CA Power Button Replacement
Выберете то, что вам нужно
  1. Asus X551CA Power Button Replacement, Keyboard Plate Cover: шаг 1, изображение 1 из 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    Спросите у FixBot
    Добавить комментарий
  2. Asus X551CA Power Button Replacement: шаг 2, изображение 1 из 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    Спросите у FixBot
  3. Asus X551CA Power Button Replacement: шаг 3, изображение 1 из 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    Спросите у FixBot
  4. Asus X551CA Power Button Replacement: шаг 4, изображение 1 из 3 Asus X551CA Power Button Replacement: шаг 4, изображение 2 из 3 Asus X551CA Power Button Replacement: шаг 4, изображение 3 из 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Спросите у FixBot
  5. Asus X551CA Power Button Replacement: шаг 5, изображение 1 из 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Спросите у FixBot
  6. Asus X551CA Power Button Replacement, Power Button: шаг 6, изображение 1 из 1
    • Locate the power button in the corner of the keyboard plate cover.
    • Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
    Спросите у FixBot
  7. Asus X551CA Power Button Replacement: шаг 7, изображение 1 из 1
    • Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
    Спросите у FixBot
  8. Asus X551CA Power Button Replacement: шаг 8, изображение 1 из 1
    • Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
    Спросите у FixBot
Заключение
7 человек успешно провели ремонт по этому руководству.
Josh
Участник с: 04/10/14
2 970 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 7-22, Regan Spring 2014 Участник Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 членов
Автор 15 руководств
1 Комментарий к руководству
I broke the middle ribbon! Do you know if that is replaceable? What part number would I order?
crwfd - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 40
За всё время: 13,339
