Введение
This guide will walk you through the process of replacing a broken or faulty battery on the Asus X751L.
Выберете то, что вам нужно
With the screen closed, place your laptop upside-down with the front facing you.
Remove the six 14.6mm Phillips #00 screws.
Remove the four 6.6mm Phillips #00 screws.
Flip the laptop over and open the lid.
Pry around the edges of the laptop base using the plastic opening tool.
Carefully lift the keyboard up.
Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
Using your finger nails, gently push the battery cable out of the connector on the motherboard.
Once the cable is disconnected, you can remove the battery.
5 человек успешно провели ремонт по этому руководству.
6 Комментарии к руководству
Very nice, thank you !
very nice, thank you !
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Your instructions were easy to follow. Thank you!!!
very helpful
