Введение
This guide covers removing the clear dome cover for the AvertX HD810 security camera. You need a T10 Torx security screwdriver and a replacement dome cover for the camera. It's advised to have the camera turned off for this procedure.
Выберете то, что вам нужно
Lift off the paintable snap-on cover from the AvertX HD810 dome security camera.
Loosen both 10mm screws on either side of the clear dome cover housing using a T10 Torx security screwdriver.
You've successfully replaced your AvertX HD810 clear dome cover when you've snapped back on your paintable snap-on cover. You can reassemble your device at any point by following the steps in reverse order.
