Введение
Using a hex 2.0 driver, you will take off the top cover in order to access the modem. With a pair of tweezers you will be able to remove and replace the modem.
Выберете то, что вам нужно
Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
Lower the plate and gently pull the ribbon out of the face plate.
