Введение
The projector's lamp is key to maintaining optimal image quality, and its periodic replacement is one of the most common tasks associated with owning a projector. All this replacement needs is a single screwdriver and about 5 minutes of your time.
Выберете то, что вам нужно
Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
Fully remove the top cover in order to get to the lamp housing.
Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
Remove the lamp from the projector by pulling on the lamp handle.
Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
4 человек успешно провели ремонт по этому руководству.
