Введение
If you are removing or replacing the Blackberry 7520 LCD screen, look here for support.
Выберете то, что вам нужно
Turn the phone upside down.
Push down on the black button on the back of the phone to slide the rear panel off.
The battery should be visible now.
Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
Use a pick or plastic opening tool to push the clips holding the rear away from you.
Repeat the process of unlatching the clips for the top section of the Blackberry.
Remove the motherboard.
Remove the indicated screw using the T6 Torx screwdriver.
Use a pick or other small tool to pop the small plastic clip holding the LCD panel on
Еще один человек закончил это руководство.
1 Комментарий к руководству
It’s too bad that iFixit didn’t post a teardown listing the parts for the BlackBerry 7520, since so little is known about its parts.
