Blu Dash 5.0 Dual SIM Display Cable Replacement
Выберете то, что вам нужно
    1. Blu Dash 5.0 Dual SIM Display Cable Replacement, Battery: шаг 1, изображение 1 из 1
      • Find the small slot on the bottom left corner of the back panel.
      • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
      • When the back panel is loose enough, use your fingers to remove it completely.
      Спросите у FixBot
      Добавить комментарий
    2. Blu Dash 5.0 Dual SIM Display Cable Replacement: шаг 2, изображение 1 из 1
      • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
      Спросите у FixBot
    1. Blu Dash 5.0 Dual SIM Display Cable Replacement, Display Cable: шаг 3, изображение 1 из 1
      • Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
      • The screw holes with the red circle around them hold screws with a 3.5 mm length.
      • The screw holes with the orange circle around them hold screws with a 2.5 mm length.
      Спросите у FixBot
    2. Blu Dash 5.0 Dual SIM Display Cable Replacement: шаг 4, изображение 1 из 2 Blu Dash 5.0 Dual SIM Display Cable Replacement: шаг 4, изображение 2 из 2
      • Insert the plastic opening tool into a corner of the plastic panel and gently pry it away from the rest of the phone.
      • Do this for each corner until the panel pops up.
      Спросите у FixBot
    3. Blu Dash 5.0 Dual SIM Display Cable Replacement: шаг 5, изображение 1 из 3 Blu Dash 5.0 Dual SIM Display Cable Replacement: шаг 5, изображение 2 из 3 Blu Dash 5.0 Dual SIM Display Cable Replacement: шаг 5, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      • Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
      • To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
      Спросите у FixBot
Заключение
8 человек успешно провели ремонт по этому руководству.
Dashaya Toney
Участник с: 10/27/14
876 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 4-7, Miles Fall 2014 Участник UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 членов
Автор 27 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 28
За всё время: 3,409
