Введение
Use this guide to replace the AUX/USB port in your device.
Выберете то, что вам нужно
Flip speaker over so that the bottom is facing up.
Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
Remove the AUX/USB port from the device.
16 человек успешно провели ремонт по этому руководству.
17 Комментарии к руководству
Any idea where I can find the USB/Aux board for sale?
Did you ever manage to find a place to buy it?
You can buy a charging cradle for this device, maybe that helps..
Try buying the wireless charger for $29: https://www.bose.com/en_us/products/spea...
I am also looking for the usb port replacement part.
