Введение
If the back lock-release lever is loose or broken, this will allow you to attempt to replace it.
Выберете то, что вам нужно
Using your finger, carefully pry open the side panel from the top of camera.
Pull panel downwards to remove.
Pull off the lever by pushing up from the bottom and pulling away from the bottom.
2 человек успешно провели ремонт по этому руководству.
