Введение
This guide will instruct you how to install the flash on your camera.
Выберете то, что вам нужно
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Using the flat end of a spudger, loosen the connection between the front panel and the device.
Remove the front panel using your hands.
Remove the flash cover to access the flash bulb.
After wires are unsoldered, slide flash bulb out from housing.
Еще один человек закончил это руководство.
