Canon EOS Rebel T5 Image Sensor Replacement
Выберете то, что вам нужно
    1. Canon EOS Rebel T5 Image Sensor Replacement, Battery: шаг 1, изображение 1 из 1
      • Lay the camera on its back so that the card/battery door is facing you.
      • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
      Спросите у FixBot
      Добавить комментарий
    2. Canon EOS Rebel T5 Image Sensor Replacement: шаг 2, изображение 1 из 1
      • Lift the now free card/battery door to reveal the battery compartment.
      • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
      Спросите у FixBot
    1. Canon EOS Rebel T5 Image Sensor Replacement, Back Cover: шаг 3, изображение 1 из 1
      • Turn the camera so that the back is facing to your right.
      • Remove the 5mm JIS #000 screw above the rubber USB port cover.
      Спросите у FixBot
    2. Canon EOS Rebel T5 Image Sensor Replacement: шаг 4, изображение 1 из 1
      • Remove the rubber piece.
      • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
      • It is held in place by a notched tether, but can be easily manipulated to slide out.
      Спросите у FixBot
    3. Canon EOS Rebel T5 Image Sensor Replacement: шаг 5, изображение 1 из 1
      • Turn your camera so that the bottom is facing you.
      • Remove the four 5mm JIS #000 screws.
      Спросите у FixBot
    4. Canon EOS Rebel T5 Image Sensor Replacement: шаг 6, изображение 1 из 1
      • Now turn the camera so that the front is facing towards your right.
      • Remove the two remaining 5mm JIS #000 screws.
      Спросите у FixBot
    5. Canon EOS Rebel T5 Image Sensor Replacement: шаг 7, изображение 1 из 3 Canon EOS Rebel T5 Image Sensor Replacement: шаг 7, изображение 2 из 3 Canon EOS Rebel T5 Image Sensor Replacement: шаг 7, изображение 3 из 3
      • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
      • Gently pry the back panel from the main body of the camera.
      • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
      • This back panel contains various control components of the camera as well as the LCD screen.
      Спросите у FixBot
    1. Canon EOS Rebel T5 Image Sensor Replacement, Motherboard: шаг 8, изображение 1 из 2 Canon EOS Rebel T5 Image Sensor Replacement, Motherboard: шаг 8, изображение 2 из 2
      • Remove all ribbon cables with the plastic spudger.
      • Gently pry up the black plastic tabs to slide out the ribbon cables
      • Take note of this black cable and where it connects to the motherboard. This is a fiber optic cable which is used for the camera flash. It will need to be reconnected after replacing the motherboard.
      • When reconnecting the fiber optic cable, simply push the black cable into the hole in the connector and push it all the way in.
      Спросите у FixBot
    2. Canon EOS Rebel T5 Image Sensor Replacement: шаг 9, изображение 1 из 1
      • Turn your camera so that the top is facing you.
      • Remove the two black 5 mm JIS #000 screws.
      Спросите у FixBot
    3. Canon EOS Rebel T5 Image Sensor Replacement: шаг 10, изображение 1 из 3 Canon EOS Rebel T5 Image Sensor Replacement: шаг 10, изображение 2 из 3 Canon EOS Rebel T5 Image Sensor Replacement: шаг 10, изображение 3 из 3
      • Turn the grip side toward you.
      • Remove the rubber grip, using the plastic spudger.
      Спросите у FixBot
    4. Canon EOS Rebel T5 Image Sensor Replacement: шаг 11, изображение 1 из 1
      • Remove the black 5 mm JIS #000 screw, located under the grip.
      • Remove the three 3.5mm JIS #000 screws on the bottom of the case.
      Спросите у FixBot
    5. Canon EOS Rebel T5 Image Sensor Replacement: шаг 12, изображение 1 из 1
      • Remove the top panel of the device.
      Спросите у FixBot
    6. Canon EOS Rebel T5 Image Sensor Replacement: шаг 13, изображение 1 из 2 Canon EOS Rebel T5 Image Sensor Replacement: шаг 13, изображение 2 из 2
      • Remove the front panel of the camera.
      Спросите у FixBot
    7. Canon EOS Rebel T5 Image Sensor Replacement: шаг 14, изображение 1 из 3 Canon EOS Rebel T5 Image Sensor Replacement: шаг 14, изображение 2 из 3 Canon EOS Rebel T5 Image Sensor Replacement: шаг 14, изображение 3 из 3
      • Remove the five silver 5mm JIS #000 screws.
      • The motherboard can now be removed.
      Спросите у FixBot
    1. Canon EOS Rebel T5 Image Sensor Replacement, Image Sensor: шаг 15, изображение 1 из 2 Canon EOS Rebel T5 Image Sensor Replacement, Image Sensor: шаг 15, изображение 2 из 2
      • The screws holding the image sensor in place is set to a very specific height. Unless they are returned to the exact same height after replacement, the camera will no longer be in focus unless the focus is recalibrated.
      • Remove the three silver 3mm JIS #000 screws from the image sensor holder.
      • Remove the image sensor holder.
      Спросите у FixBot
    2. Canon EOS Rebel T5 Image Sensor Replacement: шаг 16, изображение 1 из 3 Canon EOS Rebel T5 Image Sensor Replacement: шаг 16, изображение 2 из 3 Canon EOS Rebel T5 Image Sensor Replacement: шаг 16, изображение 3 из 3
      • Remove the three remaining silver 3mm JIS #000 screws from the image sensor.
      • Be careful not lose the springs underneath the screws on the image sensor
      • Using your fingers, lift the image sensor from the device.
      Спросите у FixBot
Заключение
13 человек успешно провели ремонт по этому руководству.
Tyler Brown
Участник с: 09/22/14
921 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 16-4, Wollert Fall 2015 Участник USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 членов
Автор 18 руководств
3 Комментарии к руководству
Thanks for the post. I was able to take this apart without damage to any of the camera parts. I am wondering if you happen to have the data sheet for the camera sensor, 704f? I cannot seem to find one.
Dawn - Ответить Поделиться
Hi. I do not see where it explains the calibration of the Sensor. Could you give me some reference about that?
ivanram - Ответить Поделиться
I reassembled on the camera no longer powers on, i checked disassembled again, checked for loose wires, ribbons, everything looks perfect and still it’s completely dead.
Edward Perkins - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 19
За последние 30 дней: 88
За всё время: 9,493
