Canon PIXMA MP620B USB Reader Replacement
Выберете то, что вам нужно
  1. Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: шаг 1, изображение 1 из 2 Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: шаг 1, изображение 2 из 2
    • Locate the tabs on the top of the panel that hook down and into the black side panel.
    • Insert the Spudger in-between the black panel and the blue panel as shown and pull the two pieces apart.
    • You will hear some snapping. Don't panic: this is just the hooks un-clipping.
    Спросите у FixBot
    Добавить комментарий
  2. Canon PIXMA MP620B USB Reader Replacement, Loosen the back panel: шаг 2, изображение 1 из 1
    • Remove the two screws from the back right black panel using the Phillips #00 screwdriver.
    Спросите у FixBot
  3. Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: шаг 3, изображение 1 из 2 Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: шаг 3, изображение 2 из 2
    • There is a tab you will have to push down to remove the part.
    • Once the tab is released, gently lift the cover away from the rest of the device to disengage the clips.
    • You will hear some snapping. Don't panic: this is just the clips un-clipping.
    Спросите у FixBot
  4. Canon PIXMA MP620B USB Reader Replacement, Take off the black side panel: шаг 4, изображение 1 из 1
    • After unclipping all the hooks, pull off the black side panel to reveal the inner circuit boards.
    Спросите у FixBot
  5. Canon PIXMA MP620B USB Reader Replacement, Unscrew 2 screws from USB chip: шаг 5, изображение 1 из 1
    • Remove the two screws from the USB reader using the Phillips #00 screwdriver.
    • The angle for removing the screws can be somewhat challenging, try not to get too frustrated.
    Спросите у FixBot
  6. Canon PIXMA MP620B USB Reader Replacement, Pull out USB chip and disconnect white wire: шаг 6, изображение 1 из 1
    • Disconnect the large white ribbon cable that leads to the USB reader. As you are pulling out the USB reader, carefully detach the ribbon.
    Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Val Fedorikhin
Участник с: 10/12/14
860 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 6-21, Maness Fall 2014 Участник Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 9
За последние 30 дней: 31
За всё время: 1,171
