Canon PowerShot A480 LCD Screen Replacement
Выберете то, что вам нужно
    1. Canon PowerShot A480 LCD Screen Replacement, LCD Screen: шаг 1, изображение 1 из 3 Canon PowerShot A480 LCD Screen Replacement, LCD Screen: шаг 1, изображение 2 из 3 Canon PowerShot A480 LCD Screen Replacement, LCD Screen: шаг 1, изображение 3 из 3
      • First, we will start by removing all of the black 5mm screws on the exterior.
      • Flip the camera upside down revealing two black screws on either side of the tripod mount.
      • Turn to the side of the camera closest to the lens to unscrew the third and final black screw.
      Спросите у FixBot
      Добавить комментарий
    2. Canon PowerShot A480 LCD Screen Replacement: шаг 2, изображение 1 из 3 Canon PowerShot A480 LCD Screen Replacement: шаг 2, изображение 2 из 3 Canon PowerShot A480 LCD Screen Replacement: шаг 2, изображение 3 из 3
      • Open the rubber panel on the side of the camera to reveal the last two 5mm exterior screws which are silver.
      • Once you have removed the last of the screws, use an iFixit opening tool to separate the two halves of the camera.
      • Take a half of the camera in each hand and gently pry them apart, pulling up on the side across from where the buttons are located.
      Спросите у FixBot
    3. Canon PowerShot A480 LCD Screen Replacement: шаг 3, изображение 1 из 3 Canon PowerShot A480 LCD Screen Replacement: шаг 3, изображение 2 из 3 Canon PowerShot A480 LCD Screen Replacement: шаг 3, изображение 3 из 3
      • With the screen now exposed, you must unscrew the three silver 2mm screws attaching it to the body of the camera.
      • Use the iFixit opening tool to lift the screen away from the body so that the only thing connecting it to the rest of the camera is the thin, orange wire cable.
      • Using your pointer finger and thumb, firmly grasp the cable and pull it straight away from the camera to disconnect it.
      Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order using your new LCD display.
4 человек успешно провели ремонт по этому руководству.
Ian Nzabanita
Участник с: 05/06/19
193 Репутация
1 руководство автора
Команда
UW Tacoma, Team S1-G5, Cardinal Spring 2019 Участник UW Tacoma, Team S1-G5, Cardinal Spring 2019
UWT-CARDINAL-S19S1G5
4 членов
Автор 4 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 42
За всё время: 1,868
