Введение
Although designed for long-lasting life, rechargeable batteries will lose their ability to hold an electrical charge and must be replaced.
Выберете то, что вам нужно
Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
Remove the memory card if it is still in the camera.
Use the Phillips #00 screwdriver to remove the single screw underneath the memory card slot door.
Remove the Phillips #00 screw located inside the top of the memory card compartment.
Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
Remove the batteries from the compartment.
Remove the three Phillips #00 screws located inside the battery compartment.
Remove the top lid of the camera.
The door to the memory card compartment will be freed and should be removable now.
Remove the two Phillips #00 screws from the side of the camera.
Open the small rubber door below this screw that covers the connectors.
Open and pivot the LCD screen to its widest open position.
Remove the rear cover by pulling it straight away from the body of the camera.
Unscrew the top 3.9mm, middle 2.7 mm, and bottom 2.9mm screws that hold the metal foundation covering the internal battery.
Gently lift up the plate as shown.
Loosen and gently pry the internal battery with the point blade probe.
4 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Excellent guide. Congratulations.
Bryn Thomas
Wales
What kind of battery is used internally?
