Введение
Use this guide to replace the control panel in your camera.
Выберете то, что вам нужно
Remove the two 2mm black screws that are located on the underside of the camera.
Remove the two 3mm silver screws from the right side of camera.
Remove the 2mm screw from the back of the camera.
Remove two 2mm screws from the bottom of the camera.
Remove two 2mm screws the left side of camera.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
Turn the camera over to the side with the lens and remove the ribbon on the left side.
After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
Lift up the button that connects to the power button of the camera so you can remove the control panel.
2 человек успешно провели ремонт по этому руководству.
