Введение
If your camera battery does not charge correctly, replacing the battery in your device may be the solution to your problem.
Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
The battery door will open, allowing you to access the battery.
Push the the orange battery lock back to release the battery.
Remove the battery.
