Введение
Changing the battery will be quite simple. All you need to do is pull the tab.
Locate the battery compartment on the back of the keyboard. The compartment is characterized as a small black square.
Use your finger to push down with a small amount of pressure on the tab protruding from the top of the battery compartment.
Remove this compartment cover carefully with your hand to completely to reveal the batteries in the compartment.
