Введение
With the help of a screwdriver, you will be able to replace the silicon buttons, so you can hear some tunes again.
Выберете то, что вам нужно
Using a JIS-1 screwdriver, remove the seven 11 mm screws located on the back of the keyboard.
Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
Flip the middle panel up so that the component board can be seen.
First, you will use a PH-1 bit to remove the 17 8mm screws circled in red.
Next, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wires, circled in orange.
Then, using a JIS-1 bit, we will remove three 7mm screws from the circuit board, circled in yellow.
After removing the circuit board, the last three screws are revealed, circled in green. You will use the PH-1 bit to remove these last screws.
Once all the screws have been removed, lift the panel and place it face down on the keys.
Under the panel are the buttons. Remove them by pulling from any corner with your fingers.
Remove all the buttons that need to be replaced.
