Введение
More than just a busted light bulb below your ceiling fan? Use this guide to replace the lighting fixture and restore the visual brilliance of your room.
Выберете то, что вам нужно
Find your circuit breaker panel and turn off the breaker that corresponds to your ceiling lights.
Do this by pushing it to the right.
Also flip your light switch to off.
Remove the two 1.4 mm Phillips head screws that hold the fixture to the fan itself.
Once loose, pull down to expose the two connecting wires.
Disconnect these wires by twisting the caps in a counter-clockwise direction.
You only need to disconnect the wires coming from the lighting fixture.
Once both caps are removed, simply pull the wires apart to remove the fixture.
Loosen the nut holding the ceiling fan piece to the lighting fixture.
This step may require a crescent wrench if finger force is not enough.
Pull upwards to remove the fan piece that holds the light fixture.
Your model may require you to twist this piece in a counter-clockwise motion to remove.
Switch out the old fixture with your new fixture by doing the last two steps in reverse order.
To connect your new fixture, locate the black wire from your light and the colored wire from the fan.
Twist these together. Do the same with the two white wires.
Your new light fixture should come with replacement caps. Twist these in a clockwise motion over your wire ends to ensure connection.
Flip your breaker back on, turn on your light switch, and enjoy your new lights!
12 человек успешно провели ремонт по этому руководству.
11 Комментарии к руководству
Amazingly instructive, informative and concise. Brilliant.
It's awesome
Just what I needed. Thanks.
Does it have remote control??
Could someone provide the name of the light fixture used in the demonstration?
