Введение
If the screen is cracked or not working it may be necessary to replace it. This guide will show how to conduct a screen replacement.
Выберете то, что вам нужно
Place the meter face down, and the back panel and screws can be seen.
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
Remove the battery from the meter before continuing.
Remove the four 7mm Phillips screws holding the circuit board in place.
1 Комментарий к руководству
my multimeter display is broken, where can i buy a new one?
