Chef's Choice M115 Motor Assembly Replacement
Выберете то, что вам нужно
    1. Chef's Choice M115 Motor Assembly Replacement, Case: шаг 1, изображение 1 из 2 Chef's Choice M115 Motor Assembly Replacement, Case: шаг 1, изображение 2 из 2
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      Спросите у FixBot
      Добавить комментарий
    2. Chef's Choice M115 Motor Assembly Replacement: шаг 2, изображение 1 из 1
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      Спросите у FixBot
    3. Chef's Choice M115 Motor Assembly Replacement: шаг 3, изображение 1 из 1
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      Спросите у FixBot
    4. Chef's Choice M115 Motor Assembly Replacement: шаг 4, изображение 1 из 1
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      Спросите у FixBot
    1. Chef's Choice M115 Motor Assembly Replacement, Power Cord: шаг 5, изображение 1 из 2 Chef's Choice M115 Motor Assembly Replacement, Power Cord: шаг 5, изображение 2 из 2
      • Carefully lift the entire motor assembly out of the case.
      Спросите у FixBot
    2. Chef's Choice M115 Motor Assembly Replacement: шаг 6, изображение 1 из 1
      • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
      • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
      Спросите у FixBot
    3. Chef's Choice M115 Motor Assembly Replacement: шаг 7, изображение 1 из 1
      • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
      Спросите у FixBot
    1. Chef's Choice M115 Motor Assembly Replacement, Motor Assembly: шаг 8, изображение 1 из 1
      • Reconnect the wires of the new motor assembly with the power cord and reassemble the device.
      • If your replacement motor assembly does not come with grinding discs or linkage pins, refer to our guides below:
      • Grinding Discs Guide
      • Linkage Pins Guide
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Zachary Grounds
Участник с: 09/17/15
592 Репутация
Автор 3 руководств
Команда
IUPUI, Team 3-3, Harley Fall 2015 Участник IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 членов
Автор 14 руководств
2 Комментарии к руководству
Any idea what might be wrong when ... stones don't spin, but you can hear the motor is turned on? Sounds like what would happen if something was jammed and the shaft won't turn BUT I've checked and the disks spin freely when the motor is off. I'm not sure it's worth messing with unless someone can tell me what to check.
Dan M - Ответить Поделиться
I’m having the same problem! I’m guessing that this problem (of the motor turning on but not spinning the wheels) is in fact the motor not working. Obviously this is an old comment, but if anyone else knows if this is true, please let me know.
Gretchen Ela - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 30
За всё время: 2,164
