Введение
A loose or faulty power switch should be replaced immediately. This can be a fire hazard due to an electrical short or choking hazard if it got loose and fell into the hands of an infant. This guide will show you how to prevent this from happening.
Выберете то, что вам нужно
Remove the two rubber feet on the motor side of the device.
Remove the five Phillips screws from the bottom of the case.
Carefully flip the device right-side-up while grasping the top and bottom pieces.
Using a screw driver, unclip the edges of the switch by pushing them inwards and nudging the switch out of the plastic casing. You will hear a click when the edges unhook from the casing.
Remove the spade connectors from the switch by pulling only on the connector, not the wire.
2 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
What kind of switch should I replace the bad switch with? Is there one on Amazon ?
