ClickN Kids Tablet Camera Replacement
Выберете то, что вам нужно
    1. ClickN Kids Tablet Camera Replacement, Camera: шаг 1, изображение 1 из 1
      • Start on the side with the camera
      • Insert a plastic opening tool into the space between the screen and the back side.
      • The screen side is black, the back side is colored
      Спросите у FixBot
      Добавить комментарий
    2. ClickN Kids Tablet Camera Replacement: шаг 2, изображение 1 из 1
      • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
      • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
      • The corners can be tricky. Make sure to separate the pieces all the way around the tablet before attempting to open it.
      Спросите у FixBot
    3. ClickN Kids Tablet Camera Replacement: шаг 3, изображение 1 из 1
      • Lift the detached screen from the camera side until you can see the inside of the tablet.
      • Don't open too fast, or you might damage the ribbons cables.
      Спросите у FixBot
    4. ClickN Kids Tablet Camera Replacement: шаг 4, изображение 1 из 2 ClickN Kids Tablet Camera Replacement: шаг 4, изображение 2 из 2
      • Be careful not to damage any wires or ribbon cables during this step.
      • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
      • There is a black tab behind the long ribbon cable. Lift up the black tab.
      • For the ribbon cable in the back, pull the black tabs on the side out.
      • Detach the ribbon cables connecting the screen to the motherboard.
      • Remove any tape that is holding down the ribbon cables. Set it aside.
      Спросите у FixBot
    5. ClickN Kids Tablet Camera Replacement: шаг 5, изображение 1 из 1
      • Pull off the tape that holds the ribbon cable to the battery.
      Спросите у FixBot
    6. ClickN Kids Tablet Camera Replacement: шаг 6, изображение 1 из 2 ClickN Kids Tablet Camera Replacement: шаг 6, изображение 2 из 2
      • Be careful not to damage the wires or ribbon cables.
      • Pull out the two black ends of the base on the motherboard.
      • Slide out the camera’s ribbon cable once the ends are loosened.
      Спросите у FixBot
    7. ClickN Kids Tablet Camera Replacement: шаг 7, изображение 1 из 3 ClickN Kids Tablet Camera Replacement: шаг 7, изображение 2 из 3 ClickN Kids Tablet Camera Replacement: шаг 7, изображение 3 из 3
      • Use a plastic opening tool to pry the camera out of its place.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Kevin Finney
Участник с: 03/22/15
562 Репутация
Автор 4 руководств
Команда
Baylor, Team 4-4, Williams Spring 2015 Участник Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 членов
Автор 8 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 35
За всё время: 1,171
