Введение
A 3AG fuse is a glass - bodied fuse designed to break an electric circuit if the current exceeds safety levels in a Commodore 64 device
Выберете то, что вам нужно
1. Detach the multi-colored wire bundles that's connected to the motherboard
2. Find the 3AG fuse located next to the joystick ports and On/Off switch
3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
4 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
The fuse is 1.5 Amp, not 3
3AG does NOT mean a fast acting fuse. It could be either fast or slow blow. The 3 means it's 1 1/4 " long, the "A" means it has Axial connections, and the "G" means it's made of glass.
