Controller Plate/Buttons Replacement
Выберете то, что вам нужно
  1. Controller Plate/Buttons Replacement, Controller Plate/Buttons Replacement: шаг 1, изображение 1 из 1
    • Follow the Prerequisite Guide on how to Replace the Battery to prepare the phone for disassemble. Remove, but do not replace the battery.
    Спросите у FixBot
    Добавить комментарий
  2. Controller Plate/Buttons Replacement: шаг 2, изображение 1 из 1
    • Remove all screws on the plastic case with a T6 Torx T-4 screwdriver, as shown.
    • Blue Circle: T6 Torx, Length 5mm
    • Red Circle: T6 Torx, Length 4mm
    • The screen and other parts are now loose and can easily fall off.
    Спросите у FixBot
  3. Controller Plate/Buttons Replacement: шаг 3, изображение 1 из 1
    • Separate the back cover from the phone. A plastic removal tool can be used here.
    Спросите у FixBot
  4. Controller Plate/Buttons Replacement: шаг 4, изображение 1 из 1
    • Remove the last two screws holding the motherboard to the device.
    • Orange Circle: 00 Philips head, Length 2 mm
    Спросите у FixBot
  5. Controller Plate/Buttons Replacement: шаг 5, изображение 1 из 1
    • Gently pull up the motherboard. Some force may need to be applied.
    • Some wires on the reverse side are still attached.
    • Make sure to line up the plastic connectors highlighted by the red circles when re-assembling.
    Спросите у FixBot
  6. Controller Plate/Buttons Replacement: шаг 6, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Break the break the data cable connection between the motherboard and the controller plate by gently pulling out the connecting wire with tweezers.
    • When the device is orientated as shown in the picture, apply the force parallel to the motherboard and away from the device, as depicted by the red arrows.
    Спросите у FixBot
  7. Controller Plate/Buttons Replacement: шаг 7, изображение 1 из 1
    • The entire controller plate should now be free from the phone. All the buttons can now be taken off by gently pressing them out.
    • If the touch-pad joysticks do not work, the entire plate needs to be replaced.
    Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Pieter Boersma
Участник с: 03/25/15
455 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 7-3, Cichon Spring 2015 Участник UMass Dartmouth, Team 7-3, Cichon Spring 2015
UMASSD-CICHON-S15S7G3
3 членов
Автор 9 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 59
За всё время: 1,857
