Введение
The port of the USB outlet on the keyboard can accumulate dust and dirt which can cause the connection between the keyboard and computer to fail. This guide will show how to replace the USB jack on the keyboard’s cord.
Выберете то, что вам нужно
Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
Remove the sixteen 5 mm length screws using the Phillips head #2.
One of the screws may be located underneath a manufacturer's sticker.
Remove the metal backing located directly underneath the white plastic casing.
Remove the motherboard and its attached cable from the plastic casing. The cord should now be free and can be replaced.
