Введение
The motherboard is the main hub of the router. It is responsible for all the functions of the router. Problems like a lack of connection, water spillage on router, fire on router, will all require a replacement of the mother board.
Выберете то, что вам нужно
Wedge the opening tool between the red top panel and the gray bottom panel.
Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
Orient the router so the narrow end of the router faces you and the ports face away from you.
The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
Инструмент, используемый на этом этапе:Heavy-Duty Spudger$4.99
Pry off the antenna connectors using a heavy-duty spudger.
Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
3 человек успешно провели ремонт по этому руководству.
