DOPO 10.1 Tablet Dual .3 mega pixel Camera Replacement
Выберете то, что вам нужно
  1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: шаг 1, изображение 1 из 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: шаг 1, изображение 2 из 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: шаг 1, изображение 3 из 3
    • You will have to remove the back of the tablet. To do this, take the plastic opening tool, and insert into the side of the tablet and twist. This will pop off the side.
    • Slowly pull up on the cover until it is completely off.
    Спросите у FixBot
    Добавить комментарий
  2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: шаг 2, изображение 1 из 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: шаг 2, изображение 2 из 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: шаг 2, изображение 3 из 3
    • You may notice that the battery is in the way. No worries, it is easy to move. All you will need to do is to gently lift up on the battery with a small constant pressure to release it from the adhesive.
    • Carefully put it off to the side.
    • Once the battery is removed you will see a gray wire. Lightly lift up, and move it out of way.
    Спросите у FixBot
  3. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: шаг 3, изображение 1 из 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: шаг 3, изображение 2 из 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: шаг 3, изображение 3 из 3
    • Locate where the camera is plugged into the motherboard. It should be on the left side of the motherboard just above the center.
    • Once located lift the black lever on the right side of the connector. This will release the camera.
    • Once the lever is lifted, pull out the camera by gently tugging the cameras connector tape.
    Спросите у FixBot
  4. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: шаг 4, изображение 1 из 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: шаг 4, изображение 2 из 3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Remove yellow tape that is securing the camera to the back cover.
    • Now take tweezers, and gently grab one of the cameras. Once grabbed, begin to twist to remove from device. Do this for both cameras.
    Спросите у FixBot
Заключение
For information you can go to http://www.doublepowertech.com/download/...
Kaitlyn Hayes
Участник с: 01/21/15
414 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 5-2, Brown Winter 2015 Участник USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 21
За всё время: 643
