Daisy Model 10 Carbine Butt Replacement
Выберете то, что вам нужно
    1. Daisy Model 10 Carbine Butt Replacement, Removing Screws: шаг 1, изображение 1 из 3 Daisy Model 10 Carbine Butt Replacement, Removing Screws: шаг 1, изображение 2 из 3 Daisy Model 10 Carbine Butt Replacement, Removing Screws: шаг 1, изображение 3 из 3
      • Make sure the safety is on!
      • Place the carbine with the saddle ring and leather thong facing upwards.
      • Locate the screw head on the cocking lever.
      • There should be one on either side of the saddle ring and one on the cocking lever assembly.
      • Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
      • Completely remove the screws.
      • Be wary of the black washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
      Спросите у FixBot
      Добавить комментарий
    2. Daisy Model 10 Carbine Butt Replacement, Removing the Lever: шаг 2, изображение 1 из 2 Daisy Model 10 Carbine Butt Replacement, Removing the Lever: шаг 2, изображение 2 из 2
      • Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
      • With your fingers in the handle, slide the lever towards the butt of the carbine.
      • Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
      Спросите у FixBot
    1. Daisy Model 10 Carbine Butt Replacement, Removing Side Screws: шаг 3, изображение 1 из 2 Daisy Model 10 Carbine Butt Replacement, Removing Side Screws: шаг 3, изображение 2 из 2
      • Once the cocking lever is removed, place the carbine with the saddle ring facing upwards.
      • Locate the screws on either side of the saddle ring.
      • Using a #2 Phillips Screwdriver, twist in a counter-clockwise motion.
      • Completely remove the two screws.
      • Be wary of the two washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
      Спросите у FixBot
    2. Daisy Model 10 Carbine Butt Replacement, Removing Top Screw: шаг 4, изображение 1 из 2 Daisy Model 10 Carbine Butt Replacement, Removing Top Screw: шаг 4, изображение 2 из 2
      • Now rotate your carbine so the top of the carbine is visible.
      • Locate the screw located above the saddle ring where the black metal meets the wooden butt.
      • Using the same #2 Phillips Screwdriver, twist in a counter-clockwise motion.
      • Completely remove the screw.
      • Be wary that this screw is a different length, and that there is no washer attached to it.
      Спросите у FixBot
    3. Daisy Model 10 Carbine Butt Replacement, Removing the Butt: шаг 5, изображение 1 из 2 Daisy Model 10 Carbine Butt Replacement, Removing the Butt: шаг 5, изображение 2 из 2
      • Place your dominant hand on the wooden butt and your other hand on the metal barrel.
      • Slide the butt away from the Carbine until it is free of the metal tongs.
      • The butt will not slide out quickly. The metal tongs grip the butt so that it is a tight fit.
      Спросите у FixBot
Заключение
Trelawney Bullis
Участник с: 10/12/14
488 Репутация
Автор 3 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 35
За всё время: 884
