Debadging a Car
Выберете то, что вам нужно
  1. Debadging a Car, Debadging a Car: шаг 1, изображение 1 из 3 Debadging a Car, Debadging a Car: шаг 1, изображение 2 из 3 Debadging a Car, Debadging a Car: шаг 1, изображение 3 из 3
    • Begin by thoroughly wetting the badge and surrounding area with soapy water.
    • Once the badge is fully wetted, wedge a strand of floss or fishing line between the car panel and the wedge.
    • Do not use metal fishing line or metal wires, as these will damage the paint.
    • Draw the floss back and forth in a sawing motion and simultaneously pull it along the badge until it detaches from the panel.
    Спросите у FixBot
    Добавить комментарий
  2. Debadging a Car: шаг 2, изображение 1 из 2 Debadging a Car: шаг 2, изображение 2 из 2
    • Use soapy water and the rough side of a sponge to remove the leftover adhesive. Other products such as Goo Gone or Goof Off are also excellent adhesive removers.
    • Be sure to monitor your scrubbing carefully. If you scrub too hard in one area, you will damage the paint.
    Спросите у FixBot
Заключение
There you have it. A fresh clean tailgate without any badge.
22 человек успешно провели ремонт по этому руководству.
8 Комментарии к руководству
Dental floss. Good idea.
Thurman - Ответить Поделиться
This thanks for this post, many of people have craze to use custom badge. This is good think you can get choice to use any of custom badge to stick on car with the Instant Adhesives.
Bryan - Ответить Поделиться
Floss is a good idea. I would suggest using a hair dryer to first heat the area to soften the adhesive. When done you can use duct tape to "lift" small patches of remaining adhesive by pressing duct tape firmly over small sections of adhesive and then lifting straight up.
Mike - Ответить Поделиться
I find ifixit's conclusion to be rather comical; To reassemble your device, follow these instructions in reverse order.
grumblerts - Ответить Поделиться
Rather than using an abrasive washing up sponge, try using a soft cloth with WD40. It will dissolve the remove the adhesive without risking damaging the paintwork.
Gordon Grace - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 43
За последние 30 дней: 182
За всё время: 24,026
