Введение
If your battery is dead or just isn't properly holding a charge, follow this guide.
Выберете то, что вам нужно
Using the metal spudger, carefully slide it under the black rubber bottom to remove it.
Using a Phillips J000 head screw driver, unscrew the 4mm screws placed on the outer corners of the metal plate.
Again, take the metal spudger, placing it under the metal plate to take it off.
Once the metal plate is off, inspect the inside of the device to be sure the battery is plugged in and there's nothing blocking it.
Инструмент, используемый на этом этапе:Tweezers$4.99
If the battery is still malfunctioning, carefully unplug the battery using tweezers.
To replace the battery, simply insert a new one into the same slot and then plug in the end to the correct spot.
After the device is assembled, power the device on. The issue should be repaired.
